Compatible Boost Solenoid
Flash202
Post by Flash202 »
What boost solenoids are compatible with k-Pro? I was interested in using the MAC solenoid also used by AEM. Would this be compatible with K-Pro?
All solenoids should work, you just may need to change a few settings depending on if it is normally open or normally closed.
Flash202
Post by Flash202 »
What settings would need to be changed for normally open or closed?
look at the boost control parameters in Smanager
sovdc5thatsme
Re: Compatible Boost Solenoid
Post by sovdc5thatsme »
Flash202 wrote:What boost solenoids are compatible with k-Pro? I was interested in using the MAC solenoid also used by AEM. Would this be compatible with K-Pro?
I am puting a 57 trim turbo on my 04 rsx s if i use hondatas boast controler will i have to have a stander boost controler too.??? :?
04 rsx s all motor dyno with 235 at the wheel!!
You will need only what is listed in the Help file:
Boost Controller Solenoid Installation
Previous Top Next
This covers the selection, connection and wiring of the boost control solenoid.
Boost Control Solenoid
While almost any solenoid can be used for boost control, it is recommended to use a 3 way solenoid designed for boost control.
The GM 3 way solenoid is a popular solenoid:
Solenoid GM part #1997152
Wiring connector GM part #12102747
Solenoids can either be normally open or normally closed. A normally open solenoid has the advantage of not running until boost needs to be increased, but has the disadvantage of not controlling boost at all if the solenoid or hoses fail. An ECU boost cut is recommended to prevent damage if this occurs.
Notes:
? It is normal for the solenoid to make a ticking or buzzing sound when active.
? Stepper motor type controllers will not work.
xproductionz
Post by xproductionz »
i got an extra boost solenoid from he greedy boost controller. Can that be wired up and is there specific instructions to do so
If it works like all other boost solenoids, then yes.
