Smanager 1.2.7 Stock P30 calibration Idle speed
alex@crx
Post by alex@crx »
After i have installed on my PC Smanager 1.2.7, uploaded Stock US P30 calibration to S300 i now have a trouble with engine idle speed when cold (to low rpm for cold engine after any seconds after start). I checked Idle speed setting & founded what Celsius & farenheit temperatures seems to be wrong. Please check. When i try to change any temperature value it shows any another value.
deafy
Post by deafy »
-40 celsius is the same as -40 fahrenheit.
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
ben
Post by ben »
Adjust the throttle plate bypass screw to open it up more or increase the IACV duty cycle to get the cold-start fast idle where it needs to be.
Follow the Helms manual for setting the idle with the idle set screw.
