Smanger freezes??
b20luda
Smanger freezes??
Post by b20luda »
Smanger freezes, only happends in the higher RPMS, it will connect again after you unplug and plug in the USB, it has done this for a long time and its quite annoying, heres what i have done
car used to have MSD ignition i since turned it back to stock besides the brand new MSD plug wires.
Im using resistor type plugs, vehicle has a Brand new oem honda engine wiring harness the ground on the thermostat housing is clean and tight, i have cleaned all the body grounds as well, i have the latest version of the software and onnborad datalogging is off, if the car just idles or curises around it never freezes up on me, what else can i do to prevent this??
The battery is relocated to the trunk but everything is connected and crimped properly no shortcuts etc etc...
Should i add more grounds? such from the ecu case to the car or what im out of ideas this makes the car hard to tune on the street!!
I would suggest OEM spark plug wires. The aftermarket wires often have a large amount of EMI that will interfere with datalogging.
b20luda
Post by b20luda »
i will try OEM plug wires and see what happends....
b20luda
Post by b20luda »
just another question here i was driving the car to work this morning, car had a bit of spark blow out and i regapped the plugs last night, which took care of my spark blow out problem, i didnt experience any freezing this moring after i fixed the blow out....any possibility that was it??
if it fixed the problem, I would have to say yes
b20luda
Post by b20luda »
well the problem is intermintant so it could come back...
smracing
Post by smracing »
As far as the Smanager freezing, you should check on your USB port. If it is a older port it will not read fast enough. I had to pick up a card with USb ports on it and run it through A PCMCIA slot. Works fine now.
b20luda
Post by b20luda »
just thought i would update this... the problem is gone it hasnt froze once...did a WOT 5th gear pull from 45 to 145 got every last second of data!!
crucian
Re: Smanger freezes??
Post by crucian »
Well I still have this problem and I don't have spark blow out. I always have to unplug the USB and put it back in. It really upsets me when I'm tunning WOT.
are you using resistor plugs?
crucian
Post by crucian »
Spunkster wrote:are you using resistor plugs?
I'm using the normal NGK V-power plugs.
so they are non-resistor?
crucian
Post by crucian »
Spunkster wrote:so they are non-resistor?
yes they are non-resistor plugs. Will an MSD box and HVC coil have anything to do with it ground wise?
You should be using resistor plugs. Aftermarket ignitions and coils may cause a lot of interference as well.
