diff air temp compensation after save
revrpm
Post by revrpm »
Hi,
I had been using the Kpro in my car for years. And recently i had update my software to 1.2.2.4. Right now i face a problem. Whenever i save a rom file and open up again. It was prompt me that the rom file is having different high and low air temp compansation. Could anyone from here experience this problem? Or would anyone be able to advice me whether i have problem with my software when i update it.
Cheers,
Can you post your calibration?
revrpm
Post by revrpm »
Hi Hondata,
The calibration is stock. The air temp compensation map is -30, -0, 30, 80 98 respectively after i save the map. The correctio figures are still the same.
Then when i attemp to change the figures on the IAT, it seem not happy with that and remain the same.
Hope to hear from you soon.
Cheers,
Hondata wrote:Can you post your calibration?
revrpm
Post by revrpm »
Hi Spunkster,
Please look thru the attach map which i had save.
Switch your unit settings to fahrenheit, open the calibration, switch to celcius, save the calibration.
revrpm
Post by revrpm »
Hi there,
Finally it works!!! Thanks for everything ...
Cheers,
Garrett_si
Post by Garrett_si »
revrpm wrote:Hi there,
Cheers,
take a look on your cam maps
a lot of work have to be done on yours
