S300 strange problems!!
Post by 2 0 3 »
I will start by saying this S300 was Installed by an experienced tuner (Jeff Evans). This ECU/S300 ran fine last season with no issues what so ever. Car sat for about 6 months. New build is done, ready to dyno and we keep having strang problems with this s300.
Updated drivers and software, Car starts and datalogs fine. 2 Green leds.
Engine running rough, pull plugs...cyl #3 looks like a brand new plug. The 1/2 hour we had the car running trying to get it to idle smoother, it was only firing 3 injectors. Injector error code now present. Traced all wiring back to ECU ok, assured good conections everywhere, checked FJO driver, all good! Assume its the ECU, swap to a stock ECU. Injectors fire on all 4 cyl.
Buy a new p28 unistall S300, reinstall S300 into new P28 (again by experienced tuner/socketer) Turn on key, S300 is online with laptop, 2 green lights. We are looking good! Fire it up, CEL, again running rough. Throw a noid light on injectors. Cyl #3 again not firing!! ECU is not grounding this injector. Again to rule out a wirring issue, we swap to a stock ecu, fires all 4 cyl no problem, No check engine lights.
Pull S300 off the board, visually inspect it. Everything looks good. Reinstall onto board. Now i have 1 Green led, 1 red led. ???
Turn Key on, ECU is online with laptop, I am able to datalog with key on engine off. I goto start car, fuel pump wont prime. Upload a new calibration. Both led's back to green again!! (so confused at this point)
Flip the Key on, 1 led red, 1 led green. About 5 seconds later, red led turns green and fuel pump primes. (so very confused) At this point i am able to start the car.
Why would i have such a delayed reaction from the S300. It is literally 5-10 seconds delay from when i switch the key on, till the ecu sends a signal to the fuel pump to prime. Those 5-10 seconds, i have a red led on the hondata, then it turns green, pump primes and at that point i can start the car and datalog fine! still only on 3 cyls though.
What the heck is going on here???? Bad S300 ?
footnotes:
-Injector error code with s300
-Cyl #3 injector not firing with s300 / is firing with stock p28
-No injector error code with stock ecu
-Swapped p28's transferd s300 to new p28 same problems
-Red led, upload calibration, now green led
-Red led with key on for 5-10 seconds then switches green
-Once green led comes on fuel pump primes, everything seems good.
We already missed one dyno apt, missed Nopi this weekend, and are scedualed to dyno again tomarrow!!!
HELP!!!!
Sounds like a problems with the FJO injector driver. I would try removing that and using stock injectors to see if the problem goes away.
2 0 3
Post by 2 0 3 »
Just to update...
it was actually a problem with the Main relay. Replaced. Running great now.
