Runnability Issue
Twistedframe
Runnability Issue
Post by Twistedframe »
Will the Hondata unit compensate for adjustment screws such as the idle adjustment screw and throttle stop screw, if they have been messed with?
A while before I upgraded to the Hondata system, I was instructed to adjust those two screws to get the car to idle properly, and after doing so, I informed the techs installing the system that I had done so, to which they replied "It doesn't matter" ?
The car has not run properly since.
It idles ok, roughly around 900 rpm. If you increase the throttle to 1500 rpms, it drops back to an idle, then slowly starts creeping it's way back up to 1500, then it repeats the pattern.
When normally accelerating, the car hitches at approx. 2800 rpm, like it's bogged down, then above 3000, it surges like like a bucking bull then runs correctly throughout the rest of the rpm range.
The really strange thing is that I can get the car to drive all the time in this "ill temper zone" by keeping the throttle at 5-10%
The only thing I can think of now is it's a vacuum leak or something to do with the fact that those adjustment screws have been messed with.
'97 LX F22B2 CD6
Make sure your TPS is reading 0% (.48-.49 volts) closed and 100% wide open. Follow the idle set procedure in the Helms manual...this involves having the car at operating temps and unplugging the idle controller and adjusting the idle via the screw. Once you have done these you will probably notice the car runs much smoother.
Twistedframe
So you can actually adjust the idle with said adjustment screws and it would conflict with the ECU's program? That's basically what I'm trying to figure out here.
'97 LX F22B2 CD6
You must follow the Helms manual for properly setting the idle
