just want to try to get some info - currently car is making peak power with vtc of 35 @ 9000 rpm redline. everyone else has vtc much lower around 20 or so with same cams & header & IM & tb
has anyone ever seen something like this?
my peak is down from where it should be (220/166 on low reading dynapack) - right where is was with stock ITR cams
setup - k20a type R, RBC, HyTech header, Hytech stg1 cams - we double checked cam timing 100 times over (dowel test on cam pickups/arrows on cam pickups, cam gear markings all at TDC which was verified with stick test & crank position markings)
I might have loose packing in a 25" burns resonator (3" inlet with 4.5" O.D) which is being replaced but I need all the info i can get before going back to dyno again - i can't afford anything anymore b/c of this dyno'ing & redyno'ing & dyno'ing again :oops:
what could be a cause for a much higher vtc @ redline
Is the resonator a straight through design? If it has louvers, that can be a restriction right there. I've never seen a n/a k20 anything tune out to want 35 degrees after 7500 rpm. It's always 20 - 25, then again, I've never done a cam tune on non oem honda cams. What base map did you start with and how was it tuned before cam angles were hunted for? Was fuel and ignition tuned out on each 10 degree cam increment?
Do you have a datalog and calibration I could look at?
Wayne
Wayne
the resonator is BurnsStainless - ultralightweight... no louvers the inside is 3" straight thru (we removed it) to inspect it but we did not take it apart to inspect the packing (which i will be doing shortly)
my calibration is posted in calibration forum (under hytech cam calibration) http://hondata.net/forum/viewtopic.php?t=6358
we originally had ending vtc around 25 with a/f tuned - the more advancement we removed the more power went up (up to 35vtc)
I was wondering if the packing was loose & exh is hitting a 25" long space with 4.5" diameter thereby obstructing velocity if that would be a cause for it liking a higher vtc
obviously i need to do more dyno testing but just wanna have all my ducks in a row b/c I can't afford this anymore (exedy stg2 clutch broke last week :roll: ) BTW we did compression & leakdown & results where 260psi & 0 respectively across the board
Garrett_si
I tuned a K20z3 this weekendRazathorn wrote:Is the resonator a straight through design? If it has louvers, that can be a restriction right there. I've never seen a n/a k20 anything tune out to want 35 degrees after 7500 rpm. It's always 20 - 25, then again, I've never done a cam tune on non oem honda cams. What base map did you start with and how was it tuned before cam angles were hunted for? Was fuel and ignition tuned out on each 10 degree cam increment?
Wayne
and I finished at 30 from 8000 to rev limit
could you help me to see how to reach better power at 20-25 Vtc degree?
I could post the map and the datalog
