boost control issue
b20luda
boost control issue
Post by b20luda »
so i sent my ecu to hondata boost control works good for the most part, but i get a nasty spike, when cruising at like 2500 rpm and going to full throttle acceration i get a consistant 12psi (i have boost cut set at 15psi) Heres the issue when in higher RPMs like 4k or so... or in first gear, nailing the throttle will results in a spike and it hits boost cut, anything i can do to prevent this spike in boost pressure?? never had this problem with my AVCR
Calibration? Datalog? How have you got the wastegate plumbed in?
b20luda
Post by b20luda »
using GM solenoid, plumbed into charge pipe just after intercooler, setting normally open, fixed duty at 20%
lines from solenoid are about 2 feet long each, i dont have a datalog but will get one if needed
CivicVTi
Post by CivicVTi »
One more question about boost control. I want to wire an external switch to D4 to run lo/hi boost. In order to activate the high boost setting, do I have to feed the D4 +12v or ground it? Thanks
D4 must be grounded.
You should try using the manifold as your vac/boost source.
Lococoin
Post by Lococoin »
Spunkster wrote:D4 must be grounded.
What is the reason for this? I tried the manifold and it seems to creep a bit less when running right off the turbo.
thudreem
Post by thudreem »
I'm having the same problem. I went from a manifold source to the intercooler piping right after the intercooler. Mounted the GM solenoid right behind the headlight. I tuned it Sat night, was a cooler night and had a little creep. Went to the track on Sunday, temperature was a lot hotter and my intake temp were 40 degrees higher and I was hitting boost cut like crazy. I tried fixed duty cycle, gear based etc. I finally disconnected the GM boost solenoid and went with a $5 manual boost controller using the same boost source (IC Piping) and the car built boost faster and held 18 psi all the way to redline (9800 rpm's)
Hondata, what do you recommend we do here??
Is the S300 ever going to have closed loop boost control with options where you can select the boost solenoid that we are using?
Post your calibration and datalog
thudreem
Post by thudreem »
Spunkster wrote:Post your calibration and datalog
OK, I will when I get home!!
thudreem
Post by thudreem »
Here is my program and a datalog where I hit boost cut with the GM boost solenoid. AS you can see I had my target boost from 2nd - 5th gear at 16 lbs, I was still hitting 20lbs boost cut. Let me know if you have any questions.
Look at your AIT compensation for boost control. You are adding 2% duty cycle above 120 degrees and since your pressure at 17% duty cycle is 20psi that is why you are over boosting.
thudreem
Post by thudreem »
OK, I will change that and see if it helps.
one more question: say I want to run 10lbs in 1st, 23 lbs in 2nd, and 30lbs in 3rd, 4th, and 5th gear.
Lets say when I was testing in the fixed duty cycle and the car ran 10psi at 12% duty cycle, 23psi at 25% duty cycle, and 30lbs happens to be at 33% duty cycle.
If I enter the corresponding PSI and duty cycle % in the parameters section and then enter in the gear based 10lbs 1st, 23 lbs in 2nd..and so on the car should hit those targets on the nose correct?
As long as you put the settings in correctly yes
thudreem
Post by thudreem »
Spunkster wrote:As long as you put the settings in correctly yes
OK, does the ECU use interpolation for boost levels that are not in the table?
yes
