Full Throttle Shift wiring
deafy
Post by deafy »
Hi,
I have a 97 prelude with p72/s300. I'm going to be using the SCS wire for FTS. My question is, which wire off the clutch switch do I use? Do I splice into it or cut it then wire to ECU? I've searched already, no luck. Thanks.
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
You must cut the wires. One goes to ground, the other goes to the input you specify.
jew
Post by jew »
will doing this mess up cruise control?
yes, just jumper the 2 wires that go to the cruise control unit together.
deafy
Post by deafy »
awesome, thanks for the help.
deafy
Post by deafy »
If both wires are snipped on the clutch switch, wont that prevent the car from starting? From what I read out of my shop manual, this is one of the components needed in order to complete the ignition circuit. This is for a 1997 prelude.
THere are 2 switches, the cruise switch and the interlock switch. You are only touching the cruise switch. The cruise switch disengages as the pedal is pressed down, interlock is engaged when the pedal is fully depressed.
deafy
Post by deafy »
Now I see the other switch. It all makes sense. Thanks for the help!
