LC1 and Hondata: AFRs are not the same
jew
Post by jew »
when i compare the afr in smanager to the afr in logworks they are about a point off from each other. i assume this is what the voltage offset is for in smanager. logworks is displaying the correct afr, right? i assume i need to edit the voltage offset so that smanager reads the same values as logworks.
logworks shows an afr of 12, but smanager shows 13 what do i need to put in the offset?
i apologize in advance for the noob question, but i'm just getting started in learning this stuff so please have patience. i'm sure i'll be posting LOTS of noob questions in the coming weeks.
You will have to just try different values until you find the one that makes them match.
rmn
Post by rmn »
i have set "-0.55" v to make afr match
wbo2 is the same you have lc-1
