Not getting any readings!
ROM Editor 4 tuning software questions and answers.
allan@strd
Post by allan@strd »
I have gotten Rom Editor 4 and have installed everything in the correct way. I have downloaded the newest version of the Rom Editor 4 which is the 1.0.7.0
When i try to datalog i get no readings at all. Is there something i am missing?
Have you burned the eeprom using the Romeditor 4 software? Is the light on the interface box flashign or solid after burning this chip and installing it?
allan@strd
Spunkster wrote:Have you burned the eeprom using the Romeditor 4 software? Is the light on the interface box flashign or solid after burning this chip and installing it?
K i tried burning an eeprom with the new ROMeditor 4, light on the box was solid. Pressed F10 to datalog and still nothing. ..............i also clicked on information to see if it was reading the blue box and this is what i got:
Cable Serial Number: 66
S200 Serial Number: (nothing)
Boost: (nothing)
Datalogging: (nothing)
G Sensor: (nothing)
3 Step: (nothing)
And my S200 that i'm using is fully loaded included G Sensor!!!
Could it be my Romeditor 4 serial cable that's messed up????
Allan
Has J12 been cut?
allan@strd
Spunkster wrote:Has J12 been cut?
YESSIR!!!!
Can you describe exactly how you have everything hooked up?
allan@strd
Spunkster wrote:Can you describe exactly how you have everything hooked up?
ECU > Interface Cable > Blue Box > Datalogging Cable > Rom Editor 4 USB Cable > Laptop
