troubleshooting
xskiesgoblackx
troubleshooting
Post by xskiesgoblackx »
i plugged my p28 with the s300 and my car started up at 500 rpm and stayed there.
and its plugged into my laptop also but im getting no feedback at all, it seems likes its just not plugged in.
anybody know whats going on?
its hooked up to my b16 crx.. i got the obd1 dizzy with plugs, and the obd0 to obd1 ecu conversion harness..
xskiesgoblackx
it says im online and everything. just nothing i put in will do anything. with that display screen up it reads nothing either.
i also dont have the 4 wire o2 sensor. but i dont need that shit to get my idle right. and its only revving up to 4k.
any help is appreciated please
Have you opened a calibration and uploaded it to the ecu? Also make sure that you have the the s300 board seated properly on all the pins.
xskiesgoblackx
it says im online on the bottom left. when i click to upload a calibration it will have the little loading bar in the center of the screen and finish uploading it. but nothing happens. still idles at 500 rpm still cant rev past 4k. what the fuck is going on.
i took the top of the p28 off so you can see the ecu. theres a red light by the usb plug on the hondata chip. and every like five seconds it will switch to green for a split second then go back to a solid red.
Please make sure that the s300 board is seated properly on all the pins on the ecu. It sounds like it is not properly installed.
xskiesgoblackx
ive checked like 4 tims
i followed this guys guide
http://honda-tech.com/zerothread?id=1348457
which was mad good. but did he miss anything. the only different thing i saw was that hondata tells you to remove the IC3 socket. so i took my ecu apart again but i couldnt even find that socket. would that be it?
Who socketed this ecu? What version of software are you using from Help, About?
