computer flashing?
minnis94vtec
computer flashing?
Post by minnis94vtec »
i just bought a 97 civic dx with a d16y7, i am adding forged rods and low compresion pistons, boosting 22psi with a 75 shot of nitrous. with 1000cc injectors. does hondata offer a computer flash for this setup.
my 4 banger will out run your 8 so ybuygm
Reflashes generally are for stock engines, or stock engines with intake only. The s300 is what you need.
minnis94vtec
is there a cheap fix? i have a deadline of the 30th to get it ready and running is there a tune that can be done through the obd2 port anywhere?
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100, s200 or s300 depending on what options you want. I would recommend the s300, and you will then have to get it properly tuned on the dyno.
minnis94vtec
i have a s200 series and a computer out of a 1994 integra that is obd1 tuned for 450cc injectors but is vtec i think the number is a p28? or is it a p72 sorry i am a newcomer but will this one work for this veh. until i get to the dyno? please help me i have a revenge race on the 30th i noticed that it is listed and has all three selected it is the p72 for gsr will this suffice with the 450cc injectors until i get to the inline pro dyno to tune?
No, that will not work for 1000 CC injectors. You will need to get it tuned on the dyno by one of our dealers.
minnis94vtec
will that computer work on the sohc that i had on my integra, only diff. is the sohc is non-vtec.
minnis94vtec
awhat i am tryin to say is that the integra was a dohc vtec and tuned for 450cc injectors and 10psi boost and i bought a harness for the 97 to convert to a obd1 and am wondering if i can switch over the computer and the injectors and the turbo setup and that computer run that setup till i get it to a swhop to tune the car.? the only diff is that the car is a sohc non vtec can you help?
COmpletely different engines will run very differently. I would recommend having your tuner giv eyou a basemap, or just towing the vehicle to the tuner to get tuned on the dyno.
minnis94vtec
ok thank you i thought thatwould be a good idea too i am just tryin to get this thing off the ground. i know that the compurter is set up for vtec and no where near this level of boost. i really appreciate your help.. whats the max amount of hp you think a d series can produce it has a fully forged bottom end and blockguard and metal headgasket 26psi. 50shot
