Tuning for VTEC Killer Cams and ITBs
aahill69
Post by aahill69 »
I'm installing VTEC KC and ITB's all at once. Which of the tables are used for tuning, the LO or the HI? Do you have to mix values from both tables into one?
If you are disabling vtec and VTC then you will just be using the low cam settings.
aahill69
Post by aahill69 »
What about tuning over 8k RPMs. The low tables go up to 8k only, and the scale is different.
jordancivic
Post by jordancivic »
Right click, delete.
Delete the lowest value on the rpm and it'll create another on the high end.
