PRC ecu A01-A12?
signalpuke
PRC ecu A01-A12?
Post by signalpuke »
Is there a more detailed list for the compatible ECUs? On this table the PRC is noted the same as the PRB. In this thread it seems the newer PRC ECU's are infact compatible with K-pro.
What is the significance of the first letter in the 3 digit code after PRC i.e. PRC-J01, PRC-O13...? Does it tell you whether the OKI chip is inside?
The OP in this thread was asking and there is no definate answer.
All PRC ecus work with K-Pro the same way. PRC's currently do not have nitrous controls as they lack the emissions features that they use. We are looking at a software update that uses alternate outputs to use these features.
