Blue Box and Heat
Doodoo
Blue Box and Heat
Post by Doodoo »
I just wanted to know if anyone has had problems with their blue box when the weather is hot.
My situation:
It has been in the upper 80s-90s here recently. I parked my car in the sun for about 5 hours. Came out to start it and the check engine was solid. My blue box was in my glove box and it was hot to the touch. I took it inside to the A/C for about an hour. Came back, hooked it up and no check engine, car started fine.
Another day I tried to start it when the blue box was hot and check engine was solid and it started fine, just a solid light. It drove normal with my program because I run 780cc. If it was in limp it would not have ran right.
This has started happening since the weather turn hot. In the winter everthing was fine. I have since moved the box out of my glove box and it still happens.
Any ideas? Thanks.
Doodoo
Post by Doodoo »
This has happened to no one?
Hondata:
Was the board components in the blue box ever tested for heat tolerances?
QUICKSILVER RACING
Post by QUICKSILVER RACING »
No problems for 5 years except for the bugs that they fixed. I live in the tropical country of the PI. TEMPs get as high as 40deg celcius.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
Doodoo wrote:This has happened to no one?
Hondata:
I've drivien my car in Arizona when it was at least 110 outside and probably 150 or more in the car, and had no problems.
Doodoo
Post by Doodoo »
Then I guess I my box has got problems. I have since moved my blue box in between my seats under the e-brake. There was not a problem when I drove the car.
I think I wil be sending my box in for repairs. I am sure th eblue box will run under adverse conditions, just not mine.
