QUESTION ON "INJ"
babybenz
QUESTION ON "INJ"
Post by babybenz »
All,
When car is idling and I throttle it to say >3000rpm, I notice that sometimes, the "INJ" in my S300 "DISPLAY" sometimes shows "0" in green then back to some readings again. Is this normal?
I am driving an EG6.
Regards
+65-9296-5336
Are you having a problem?
Sounds liks fuel overrun cutoff.
babybenz
Post by babybenz »
Spunkster wrote:Are you having a problem?
SS,
Yes, I am having a problem and that is engine stalling problem.
I notice that when the "INJ = 0" happens at a lower rpm when I rev to 3-4k rpm, the rpm will drop to very slow and many times stalls.
When the "INJ = 0" happens at a higher rpm, then rpm drops but does not go below 1k rpm (this is the set idle rpm).
Sometimes, the "INJ = 0" never shows at all.
Regards
+65-9296-5336
Please post datalogs and the calibration that shows the problem.
deafy
Post by deafy »
I think injectors dont spray at all if you let off the gas completely and rpm's drop till idle speed and it starts spraying. Hence the INJ=0
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
