Boost control and co2?
Upperguy
Post by Upperguy »
can you use a co2 pressure source with the hondata boost controller? this is for a drag only app would that give the solenoid a broader controllable boost pressure?
Sure you can
Upperguy
Post by Upperguy »
great news!!!
thanks
figured d try without Co2 first but if i wants getting the desired effect the Co2 should make that better
2 0 3
Post by 2 0 3 »
we plan to run C02 as well! Let me know how it works out.
ares650
Post by ares650 »
would it be setup the same way?
SFWD 1934
Post by SFWD 1934 »
CO2 is an awesome way to control the boost for you. Say you are at a high density altitude track, and the conditions are not very good (weather i.e.) you do a run look at the log and see you only made 65% of total target boost. Well let's just say that 65% was 23PSI and your target is 35PSI. Now you can use the CO2 to keep those wastegates where you want them, so that you can make that target boost. It also allows you to run more boost pressure on a smaller base spring. Rule of thumb is 2 times the base spring (so if you had a 10lb. spring the most you could typically go is 20lbs. before you start seeing an issue with boost holding for you). Once again the CO2 can be regulated out to hold that pressure for you. No more having to open the wastegates and change springs.
Jason
9.86 @ 152
