i know this may sound dumb i have to ask
89jdmef9
Post by 89jdmef9 »
is there any stand alones for a obd 0 ecu or do i have to convert to obd 1 if so if i just used the piggy back would that work fine or would i have to do the hole harness ?
planetspeed
Post by planetspeed »
You just came to the right forum to get answers to your question..You can go with the early Hondata S100 or S200 for your OBD0..Piggy backs will cost you more and with a limited scope of tuning..For the bang for the buck standalone ecu specifically for B,D,F,H-serieshondas, I strongly recommend going for the S300 on an OBD1 ecu for a few more extra bucks and be one of the quicker hondas in your locality!
The s100, s200 and s300 will not work with an OBD0 ecu. To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100, s200 or s300 depending on what options you want.
planetspeed
My apologies for the typograpical error on the OBD0 instead of OBD1..
89jdmef9
haha
Post by 89jdmef9 »
[ yea ur tellin me it sucks but i know this guy that would change out my hole harness for 400 hundred it would be cheaper but some one did it already and he sayed he don't like touching other poeples work but i heard hes really good so i might do that then the stand alone
Clutch
Re: i know this may sound dumb i have to ask
Post by Clutch »
89jdmef9 wrote:is there any stand alones for a obd 0 ecu or do i have to convert to obd 1 if so if i just used the piggy back would that work fine or would i have to do the hole harness ?
You could get yourself the old Hondata stage systems. I had a old stage 3b that I had on a obd0 ecu, worked great. Not using know, but still have the stage system to this day. Good luck
scttydb411
Post by scttydb411 »
get a boomslang obd0-1 conversion harness, p28 ecu, and obd1 dizzy, and s200 or s300.
HONDATA DEALER/TUNING IN ATLANTA!!
DIGITALBOXTUNING
678-614-3596
89jdmef9
Post by 89jdmef9 »
thanks for the help to all i really have to look in to it .
