Rev-set button
spoolind16
Rev-set button
Post by spoolind16 »
Does the rev set button on the s200 still work with a RomEditor v4 Rom? I'm just curious if I can set the lanuch control and such with the button?
Yes you can, but the chip must be burned with the corect inputs for it to work properly.
spoolind16
Spunkster wrote:Yes you can, but the chip must be burned with the corect inputs for it to work properly.
What are the correct inputs? I'm using the stock cruise control clutch swich and the Rev-set button included with hondata.
Look at the Launch control and full throttle shift inputs in Romeditor 4 parameters. Even though it lists the s200 clutch switch input, you cannot use it.
spoolind16
Spunkster wrote:Look at the Launch control and full throttle shift inputs in Romeditor 4 parameters. Even though it lists the s200 clutch switch input, you cannot use it.
What would work better then? If I use the A\C switch do I have to do any additional wiring?
