Step Retard Ignition
boost charger
Post by boost charger »
Is there gonna be an update to s300 that enables you to do step retard on the ignition for boost?
Bore & Boost!!!!
"God created turbo lag to give v8's a chance" by TurboEK from SNI
http://www.cardomain.com/id/skrigz
What is step retard on the ignition for boost?
There is an option to retard the ignition while on the launch limiter in order to build boost - is this what you mean?
boost charger
[quote="Hondata"]What is step retard on the ignition for boost?
/quote]
here is a pic of what i'm talkin about
Bore & Boost!!!!
You do this when you create a new calibration under 'create boost tables'.
Since you can control the fuel/ignition tables you really do not need this. You simply need to go into the tables and make whatever adjustments you want to make.
