Hondata not reading wideband via ELD
deafy
Post by deafy »
I have an LC-1 (brown wire) hooked up to the ELD (green/red wire) off the ECU harness, and it is also cut as shown in the picture. Disabled ELD in SManager and set Lambda to D10 - ELD and etc. The readings don't show up at all. I just get a solid green 0.00. My wideband gauge is reading everything just fine. I used to have the brown wire hooked up to the stock o2 sensor wires and it worked great. I wanted to switch over to ELD so I can switch in and out of closed loop. Any idea what I'm doing wrong?
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
Are you getting voltage readings with a multimeter on the output from the Wideband controller?
deafy
Post by deafy »
Haven't checked that, however, the yellow wire runs off the LC-1 too and the gauge is picking it up perfectly. I'll check it later when I'm able, but are there any other suggestions?
planetspeed
Post by planetspeed »
As your datalog says, the lambda settings are still set to stock O2 source and 0-1V conversion table..modify it to suit the LC-1 voltage conversion table and save it to your existing map program..saving changes after modifying your map is needed..goodluck!
deafy
Post by deafy »
they were set to d10 ELD and etc... i checked everything... The program itself saves the wideband info as the default for the program but doesn't save it to calibrations. I tested this by saving a random calibration with o2 set to stock, closed the program, reopened it and opened a different calibration with it, changed o2 to d10 - ELD, closed, reopened with the first calibration i saved and it was set to d10 instead of stock. Maybe a bug?
planetspeed
Could be a bug..so have you rectified your problem already?Do you have the correct reading already?
Wideband lambda input information is a program setting, and is not saved per calibration.
deafy
Post by deafy »
Is there a reason for that?
planetspeed
Deafy,
Do you have readings in your laptop now?I think we're drifting from your problem already..update please..
deafy
Post by deafy »
I checked the voltage of the wire coming out of the wideband controller and it seems to be reading correctly. I suspect the culprit might've been a bad wire between the WB wire and ELD wire. I've not had a laptop around to check if it works, was borrowing a friend's. I'll get an update soon though.
deafy
Post by deafy »
Checked into my problem... WB is wired directly to D10 wire as usual and still reading 0.00 volts. I have checked the WB output with a voltmeter and it works perfectly fine. My connections are pretty well bound. I put a voltmeter to the ELD (red tap to ELD and black tap to chassis ground) and it read something like 4.55-ish, then checked after WB warmed up, it read 2.35-ish (4.55 minus AFR reading of 1.20 equals 2.35). Please help!! I really wanna tune my baby!
you either have the settings in software wrong, or you do not have it wired into the ecu correctly.
ocase22
Post by ocase22 »
Was this issue ever resolved?
deafy
Post by deafy »
Still unable to get ahold of a laptop to do any troubleshooting.
ocase22
Post by ocase22 »
deafy wrote:Still unable to get ahold of a laptop to do any troubleshooting.
I had a similar issue, mine was just solid green.. Where are your grounds? Your diagram above doesnt even mention where they are. Hope this helps.
