Nitrous control for shift light
sprinto7
Post by sprinto7 »
I'm trying to set the nitrous 1 control up to run a shift light bulb.
One side of the bulb (1057) goes to 12v, other to E connector (all the listed connections)
Fuel 0, retard 0, engine speed 3500- 8000 (launch RPM), load 0- max bar, throttle 0-100, vss 0-158 (internal vss signal).
Watching the KPro sensors I can see nirous 1 armed, and at 3500 RPM nitrous 1 turns on. Darn light bulb doesn't light.
ECU E connector pin at 12v all the time.
The VSS signal from my Toyota transmissioin is not reliable.
HELP!!!
Del Long
Try using E18 (AC Clutch). With the engine off, invert the output and the pin should be pulled down to ground.
Garrett_si
Post by Garrett_si »
here are my setting for my shift light, using a relay on pin E20
Engine load 13-0 kPa? Try 0 - 200 kPa.
Garrett_si
I just see it
I will take a look if it still working :roll:
0-200 will be better for sure
