s300 knock sensor with a p28. analog input possible?
sq_creations
Post by sq_creations »
I have a p28 with hondata s300. I pull my plugs all the time to check them but I was wondering if I could use the knock sensor on the motor in dataloging too. I saw that there is a analog input now. What kind of signal does the oem knock sensor use. Its a one wire from what i can tell can i just send it to the input on the ecu. I need to add a cap to the ecu too right?
The knock sensor can only be used with the ECU's that come with an extra circuit board inside for knock control (P72, P30, P61).
sq_creations
bummer. I was hoping it was something i could add like vtec or the boost controller.
