Kpro for Element
compdoc777
Kpro for Element
Post by compdoc777 »
Ok, I know they have the Kpro for the Element, and I want to run a turbo in the Element.
Ok, BUT I am doing the Frankenstien conversion to the K24. If you don't know what frank is check this link.
http://forums.clubrsx.com/showthread.ph ... ankenstien
Anyway, I am going to run the Type S 6 Speed trans as well on the Element.
Should I use the stock Element harness for the Engine or Use the Type S harness?
Everything should work, but i'm not sure if the transmission will fit in the Element. You may hav eproblems with the speed sensor depending on what year the transmission is from. You will also need to run additional wires for the reverse lockout.
HONDA GHANDI
Post by HONDA GHANDI »
Use the stock Element trans and harness. Just add the Type S gears internally and forget the reverse lockout. It is not needed. If you have any questions get a hold of me, I have pioneered the turbo Element scene. :D Oh, BTW hondata, finally got the Element to go 13.3@109. Soooo close to 12s before the track closed this year.
High altitude tuner www.tcperf.com
