Getting Booted out
WickedCivicNY
Getting Booted out
Post by WickedCivicNY »
I had an issue the other night on the dyno, As I was in the middle of the pull. Smanager crashed and locked up. In order for me to reconnect I had to Kill the process of Smanager and restart it. Has anyone else ran into issues like this ? Typically I would get booted out on high boost pulls around 37psi..
Any comments or help would be appreciated.
What spark plugs are you using? resistor or non-resistor?
swappedturboej6
Post by swappedturboej6 »
how is he so pose to run non-resistor type plugs with 37psi? the coldest non-resistor type is ngk7s.
WickedCivicNY
Spunkster wrote:What spark plugs are you using? resistor or non-resistor?
Its a NGK Non-Resistor Plug #10
That is the problem. You must use resistor type spark plugs. The owners manual for your car actually states this as well.
WickedCivicNY
Spunkster wrote:That is the problem. You must use resistor type spark plugs. The owners manual for your car actually states this as well.
Any recommendations you have on a resistor type plug that has a very cold heat range ? similar to the NGK 10's ?
WickedCivicNY
Excellent .. Thanks a bunch
