New calibration
picnic_george
New calibration
Post by picnic_george »
Well since I had issues before and everything is supposed to 100% correct. I want to make sure I'm doing step by step everything as it's suppossed to be.
I would like this defined a little better.
4. Create a new calibration from File->New, adjusted only for injector size.
The ecu is a p28... Does that mean I should upload the stock p28 file and just adjust for the injector size and try to start it? Should I adjust for the map sensor as well? It's a 3 bar. I already built a base tune that should be ok for start up and what not.
Should I not use that base tune initially and upload it later or completely remake another tune? Or is it ok to use this for initial upload? It was a tune I downloaded and modified the heck out of to fit my desires.
Your help is much appreciated.....
You can try any calibration you want. You will have to make changes to it based on what you have done to the car and then tune it on the dyno.
