idle problem
quickaccord93
idle problem
Post by quickaccord93 »
Hi
I just want to know if there is a way to raise the idle speed with the s300
The big problem is, when it's cold, I need to push a little the gas pedal, the warm up the engine, if I dont do that, the idle speed is 500 rpm and it's stall
I have a trottle body obd2 with no fast idle and no ajusting screw (came with my h23a VTEC 2000)
The h23a came with a 3 wire idle valve, now I have a 2 wires IAC
In smanager, I try 900 rpm to 1500 rpm for the idle, no change
Thank for your help
If there is no idle adjust screw, you may need to find a different throttle body.
quickaccord93
thanks for your answer :D
do i need a fast idle valve if I only run the car at summer
Fast idle valve is not needed, but may need to be fully blocked off as sometimes they fail in the open position.
quickaccord93
ok thanks :)
