Two Step With Kpro
jjcr2011
Two Step With Kpro
Post by jjcr2011 »
Hello. I have a Swap of K24 in Civic 92. I need to put the two step. What cables in the Kpro i need to cut to put the sensor. And the program use the launch revolution limiter???
Please help me
There is no 2-step in Kmanager. There is a standing rev-limit that can be set in Parameters under the Rev Limits tab.
jjcr2011
Post by jjcr2011 »
Ok The sensor of clutch? Whats cables i need to put in the Wiring Harness for the rev limiter function.
There is no wiring for this, It does not use a clutch switch. Please look at the Paramaters under Rev Limits.
jjcr2011
Post by jjcr2011 »
Ok. What form i use the rev limiter. I set 5500 and not work. The engine to this revolution no set bum bum bum bum. You understand.
post a datalog and calibration
jjcr2011
Post by jjcr2011 »
This is my calibration. Please help me
Can you please post a datalog showing the problem, as I do not understand your description of the problem.
