Boost control issues
civic_1992@yahoo.com
Post by civic_1992@yahoo.com »
cal is attached, just trying to get the bugs worked out of this thing before I start trying to tune it, sorry I do not have a datalog
my issue is no matter what I set the boost control solenoid duty cycle to, I am hitting boost cut (15psi)
every thing is wired and hooked up according to smanager instructions, using the recommended GM solenoid
I'm sure it is something stupid that I am missing, but I am new to hondata, any help is greatly appreciated
vehicle is 99 SI
1.9l 84mm b16
stock head, supertech valves
off the shelf turbonetics turbo kit (log mani, small t3/t4)
boost source is from the intake mani, tee'ed to the solenoid
I would like to start tuning this car around 15 psi, and then move to a boost by gear setup, but I need to get the boost control working correctly
the only other thing worth mentioning is that I wired the boost control solenoid to pin a11 on the obd1 computer at the obd2-obd1 conversion harness. I am not 100% sure if that is correct, if I need to wire to something else or to the engine harness, then I apologize for such a long post
you don't even have boost control enabled in the calibration
shows you what a noob I am, I think I posted the wrong cal. yeah definitely the wrong cal. I was just using that first one the check the map sensors
please check this one, thanks for your quick response
You must also post a datalog showing the problem
I will try to get a datalog, again thank you for the quick response
