noob that needs help s200
bangballs
Post by bangballs »
ok just did a swap b20/b16-v-tec in my eg. purchased a s200- sn 3500..... ecu is socketed. would like to know what options my s200 has and if i can do a base map myself. i have 440 injectors t3/t4 turbo 9 pounds of boost. can u tell me if i can do this myself or do i have to go to a dealer, the dealer is 2 an a half hours away and they wont be able to do it for another month witch i would like to get the car running.if it doesn't come with the boost option would i be able to unlock it myself. any help would be appreciated cause im a noob
This system has datalogging only. You will need to purchase any upgrades through your tuner/dealer. If you wish to tune yourself, I would highly recommend just upgrading to the s300 as it will be cheaper.
http://www.hondata.com/s300upgradeform.html
With the s200 any basemaps will have to be done by your tuner or dealer as well.
bangballs
Post by bangballs »
is there any way to unlock the boost option and get a base map with out going to the dealer. im not trying to be cheap but iv'e had this kit for two years now and if i upgrade, it will probably be another two years before i drive the car
