European Honda
roet
European Honda
Post by roet »
Hello,
Can the Hondata system (s100/s200/s300) be used on european cars 2.2 Prelude for example from the mid-90's ? Are these all OBD-1 ?
Are these ecu's bothered by checksum recalculations?
To tune these cars i need a board and the rom-editor?
Thanks in advance.
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html You can then use the Hondata s100, s200 or s300 depending on what options you want. IF you wish to tune yourself, I would recommend the s300.
