K20Z3 reflash & nitrous
marecki7
Post by marecki7 »
Is it safe to run a 55 shot of N2O with a K20Z3 reflash?
On the main page of Hondata.com for the K20Z3 reflash, it states that cam angle will be advanced. After doing a search on this forum, I found some posts, stating that it is NOT safe to run N2O w/reflash (however the reflash was for DC5 not FG2)
On 8thcivic.com someone claims that it is ok, since the reflash does not advance timing: http://www.8thcivic.com/forums/showthre ... os+reflash
I'm a bit confused. Please clarify this issue for me.
Thank you
Ignition timing has not been changed. It is just as safe to run nitrous as with the stock ECU.
marecki7
Post by marecki7 »
Thank you :-)
