Hands-up who wants to supply me what i need?
doo0T!doo0T!
Post by doo0T!doo0T! »
I'm based in New Zealand and our ECU's here are the JDM square case type which require the S300j type Hondata ecu board but the JDM ecu's are not modifiable for boost control.
Our NZdealers will not supply an S300 capable of boost control so i have to source one myself with a USDM ecu.
JDM PR3's are modifyable but the ya re very expensive to buy compared to the likes of a P28.
I am willing to purchase the completed unit if anyone here is able to assemble and supply. Or can suggest someone who can.
Ideally I want to buy the assembled and ready to go unit;
P28 ecu modified and socketed for boost and USB data logging
S-manager software
OBD0 -OBD1 Harness adapter
GM map sensor
GM solenoid
If it can not be supplied assembled and prepared then individual components will be acceptable.
This is serious I am not just testing the water here.
Please PM me if you can help source what I need.
I have also emailed a bunch of US dealers but it's difficilt to find anyone willing to supply the ecu and ship internationally.
Thanks,
Mike
(we do have Hondata dealers here in NZ but I need a USDM case and the dealers here only have the JDM case type units which take the S300j) I want this for a turbo application so an S300j is not what i want.
I do not want to run an external boost controller.
-JDM EF7-Si CRX ZC/d16a6 hybrid turbo
-JDM EG5-Si hatch with H22a swap
-JDM EJ7 coupe, evo H2B with H22a-EuroR
The dealers in New Zealand can order everything you need directly from us without any problems. THey just need to order it and specify exactly what they want. What dealers in NZ have you contacted?
doo0T!doo0T!
Spunkster wrote:The dealers in New Zealand can order everything you need directly from us without any problems. THey just need to order it and specify exactly what they want. What dealers in NZ have you contacted?
Both Evan at Speedfactor and the Andrew Short :wink:
Evan said to use the units he had in stock but with an external electronic boost controller. But I'm not interested in doing that as the main reason for me wanting to use the S300 is for it's boost related functions like stepped boost in gears etc.
Andrew understood what i wanted but has confessed to having little expertise with boosted applications and has said he would not be confident to tune it himself.
I have not yet contacted Speedsource, they are not listed on your dealers website but have a growing reputation here as being excellent tuners of Hondata ecus. I dont think they are dealers though.
Evan didn't seem to be interested in importing the parts i need and Andrew wasn't really interested as he's an NA man.
At the end of the day I dont care where I get the bits from as long as I end up with the solution and functions i want.
The reason I was interested in privately importing from a US based dealer is because they would be experienced with the boost related hondata components.
Thanks,
Mike
joel1188
Post by joel1188 »
i have everything that you need.
hit me via email and i can hook you up.
joel @ driven . com . sg
thanks
