kpro pboblems help
benjiman
kpro pboblems help
Post by benjiman »
good day my ecu # is 4020 and the k20a swap is done in a 2000 integra type r i got the car started but it would not idle and has no power the error codes im getting are 8-1 dct p1361 tdc sensor intermittent signal interuption/ 10 dct p0113 iat sensor hight voltage/414 dct p1166 heated o2 sensor 1 primary (h02s) i loaded an stock tuned calibration for k20a2 to the ecu i dont know what im doing wrong any help would be greatly appreciated thank you also the car back fires when i try to start
Who did the harness for the car? At this point it sounds like a wiring issue or a damaged ecu caused by faulty wiring.
benjiman
Post by benjiman »
hasport did the sub harness and i wired it up
You can put your ecu in a known working car and that will allow you to rule out the K-Pro/ECU as the problem. ONce you haev ruled that out, you will have to start following the Helms manual for the error codes you are getting.
