Rev bouncing up and down after WOT when idle
joejoe3
Post by joejoe3 »
I have a question I would like to ask...
I'm currently supercharged at 11psi, and everytime when I go wide open throttle and then come to a full stop at idle, the rev will bounce up and down between 1000rpm to 2000rpm continously.
I can get it to go away by either driving it off or shutting the car off... does anybody know why it's doing this and how to fix it?
I tried the idle slider (to the left), the further left I go, the more it helps the situation (I think it acutally went away); however, the further left if goes, it also causes the idle to dip when coming to a stop under cruise or from WOT and stalls the car.
joejoe3
Post by joejoe3 »
btw, i checked all bolts and nipples and there is no vaccum leak
joejoe3
Post by joejoe3 »
- serial number of your K-Pro: 00713
- the calibration (as an attachment)
- a datalog of a problem (as an attachment)
- what sort of vehicle you have: 2003 Acura RSX Type-S
- what sort of ECU you are using: K-pro, upgraded from stock ECU
- Injen Cold air intake, DC race header, tanabe exhaust, Hondata IMG, Jackson Racing Supercharger, AEM fuel rail, RC 750cc injectors, 3.0" (11psi) pulley.
http://www.hondata.net/forum/viewtopic.php?t=4044
Adjust your TPS so that it reads 0%. Flatten the cam angle tables just above idle and also reduce the ignition timing.
Remember that also a vacuum leak or stuck idle valve can cause this problem - and both are fairly common occurances.
joejoe3
Post by joejoe3 »
It's funny, because this only happens at idle after I put the car under WOT. If it's normal driving it wouldn't do this.
Also, I also got a question regarding to the idle.
At idle (set at 900rpm), the car will dip into 830-840rom for a quick second and you can feel the car hesitate for a bit and come back to 900rpm.
When i did a datalog, everything is fine... but as the rpm dips, ignition jumps up to 10... when it gets back to 900rpm, the ignition value goes varies back to 1-4
joejoe3
Post by joejoe3 »
I found this in one of the reply's HONDATA gave in a misfiring thread at idle:
Welcome to Honda's ignition controlled idle speed. -2 to 10 degrees ignition timing is normal at idle - the main table is not used.
so that means it's normal for ignition to jump to 10 at random and rpm will dip 40rpms or so and hestitate?
