Uploading problems
EG2.0T
Uploading problems
Post by EG2.0T »
I have a weird uploading problem. Whenever i choose to upload a calibration there is an error. But if i keep trying to upload the calibration more 30 times it eventually uploads. After iit does upload it is easier to upload the existing calibration on the ecu with only a few tries. The datalogging works fine and downloading from the ecu works fine as well. I can real time update no problem too. Any ideas?
It shouldnt be too much of a problem since i did get the b20 basemap uploaded after like 30 tries. We will have to find out when i do get my street tune if there is any other problems.
I also tried to load Smanager then open a new calibration, put the car on the on position then tried to upload to try to get the firmware update prompt to come up. All that comes up is the upload progress bar and it stops and comes on 2 more times then goes prompts that the upload has failed.
Hardware version: 0.01
Serial Number: 0102
Datalogging: 16Mbit
Firmware: 1.03
Software: 1.29
ECU is P28
Car is EG civic with b20 turbo
t3/t4 on 450cc injectors
Les
Make sure when you allow it to upload that you are not datalogging at the same time.
EG2.0T
Post by EG2.0T »
ok i will try that right now.....to turn off the datalogging the lighting symbol should not be depressed correct?
EG2.0T
Post by EG2.0T »
well i tried this morning and everything works perfectly...i dont know why it wasnt working yesterday...i had the datalogging off and on today while upload and it worked fine....weird...has anyone ever experienced such a on and off thing?
