shift light output to auto meter shift light?
turbotypeR
Post by turbotypeR »
Does anybody know if there is a way to hook the shift light output to an auto meter shift light? I assume there is a pin out to the check engine light that can be used. Is it + or -? I would like to be able to control a shift light from the parameter menu insted of using pills in the light.
92 civic Si
best et:9.43best mph:164
The MIL outpupt is a ground. You should probably use a relay to operate a light that draws that much current.
turbotypeR
Yeah, I figured I could use a diode to isolate the output and a relay to trigger the light. I just needed to know the output. The mil light is not bright enough to see when racing. Thanks!
92 civic Si
boostedcivicsir
Re: shift light output to auto meter shift light?
Post by boostedcivicsir »
here is the pinout.
hope it helps. i am assuming you are obd1 he hee.
turbotypeR
thanks. I have already done it though
92 civic Si
ibiot
Post by ibiot »
i did that once. i ripped out the bulb in the shift light and CEL and put in a really bright LED and 470ohm resistor from radio shack, worked great. the shift light became my new CEL.
tpham_autotecks
shift light with s300
Post by tpham_autotecks »
can you show me how to do it? in proper way too
i have s300 my red line was 7000.00 it is working when i het at 7000 but my CEL light up not the up shift light. can you show me how to wire up to upshift light not the cel light. i want to keep my cel light for diagnostic if something happen.
thudreem
Post by thudreem »
turbotypeR wrote:Does anybody know if there is a way to hook the shift light output to an auto meter shift light? I assume there is a pin out to the check engine light that can be used. Is it + or -? I would like to be able to control a shift light from the parameter menu insted of using pills in the light.
Wow, I was thinking of doing the same thing!! Does it work well on a sunny day?
Boosted91
Post by Boosted91 »
i agree show us how you did it.
turbotypeR
i just hooked the mil light output to a relay via a diode and hooked it to the shift light.
92 civic Si
Boosted91
Post by Boosted91 »
if the mil light is a ground signal why bother use a diode? the relay could trigger from the ground with out feeding back and signal right?
turbotypeR
i used the diode because i left the mil in the dash hooked up. i just taped into the mil wire and used the diode to make sure there was no backfeed into the mil wire
92 civic Si
