Euro CTR datalog ELD voltage
tuono
Post by tuono »
Hi,
I am spanish,
How can i do in the last version 1228 datalog with ELD voltage?
I don,t see in the last version.
Please.
Go to Options, Settings, Wideband Input. You will see the options there.
tuono
Post by tuono »
Ok,
But this before in 1.2.2.3 appeared in closed loop.
I have AEM UEGO WIDEBAND CONTROLLER.
HOW CAN I CONFIGURE IT?
THANKS
you cannot run in closed loop using a wideband. You must still use your narrowband to run the car in closed loop. You will only be able to datalog the wideband readings in the software.
