Kpro n00b...
abdultaiyab
Kpro n00b...
Post by abdultaiyab »
Hi guys,
finally got my kpro (cheers to Hondata :D ).....i wanted to know which base map would suit best for my application...
Car : Euro Civic Type R
Engine : K20A2
ECU : PRA
Mods : AEM CAI / ITR 4-2-1 Headers / Spoon Catback / Hondata IMG / Mugen Thermostat & Fan Switch
i was thinking of using the rsxcoldair.kal....think this good enough for now?? also will i notice any usual behaviour from the kpro when first fitted (even for a few minutes) ??
If you have a PRA ecu you must use a PRA calibration from File, New.
abdultaiyab
idealy yes...but i have read about many users converting the rsxcoldair.kal and using it with no problems what so ever...
This is not a suggestion. You must use a PRA calibration, or you will have problems at some point. We created separate PRA calibrations for a reason.
abdultaiyab
thanks for the advise....i also wanted to know if the engine needs to be running while i upload the cal or just switch on the ignition key and upload the cal??
Uploads should be done wiht the car not running with the key in the ON position.
abdultaiyab
yup did that...uploaded the civictypertuned.cal....hopefully ill see some difference once it "bed in" :D
Mr Aryan
Post by Mr Aryan »
welcome onboard abdultaiyab... :wink:
Spunkster, is it possible to copy/paste the tables only?
like you've added an RSX-S with crower stage 2 cams calibration, and i have same set-up on my euro CTR, would i be able to just copy/paste the tables and fix the a/f ratio only? :roll:
abdultaiyab
Mr Aryan wrote:welcome onboard abdultaiyab... :wink:
Thanks Mr. Aryan.....i had a question for you too mate...you are in Bahrain, are there any good tuners there who can tune k20a with kpro? i am struggling to find someone here in Dubai
Mr Aryan
Post by Mr Aryan »
abdultaiyab wrote: Thanks Mr. Aryan.....i had a question for you too mate...you are in Bahrain, are there any good tuners there who can tune k20a with kpro? i am struggling to find someone here in Dubai
we only have 2 euro CTR's here including mine and a DC5. i'm the only with Kpro...
i don't think you'll find any tuner in the region, as all the guys who're having the Krpo (Kuwait mostly) they are just like us playing with the Kpro.
you either tune it your self, or if you really have the cash and your car is fully moded you want a final tune for it, get some tuner from UK and let him tune it for you.
just my opinion.
abdultaiyab
Mr Aryan wrote:we only have 2 euro CTR's here including mine and a DC5. i'm the only with Kpro...
just my opinion.
lol....then that makes me the only one to own a kpro in UAE....i cant even think of going further with N/A mods simply cause of this reason :cry:
No you should not try copying and pasting tables, as there are other differences and you will just create more problems for yourself.
