can someone convert an S200 file to my s300?
nchatch
Post by nchatch »
having a couple problems, uploading one of my maps to my racecar, i can get a few to come up but was having an issue saving saving them.
i figured it out now but i dont have a decent copy of my maps that i was able to run 10s well tuned on.
thanks
In Smanager, just go to File, Open, locate the folder where you bin file is, make sure you select Files of Type : ROM files (*.bin)
then you simply open the bin file you want to use clicking ok and not changing anything in the conversion window. Upload that to the s300 and it should run just as your car did with the s100/s200.
nchatch
Post by nchatch »
for some reason when i go to open this file it says
"not the correctsize"
or
"is not a rom image"
like i said i opened it before and when i saved, i saved it wrong,now i cant open it
Once the file has been overwritten incorrectly it is not able to be undone.
A bin file must be 32Kb in size.
nchatch
Post by nchatch »
Spunkster wrote:Once the file has been overwritten incorrectly it is not able to be undone.
DAMN :x thats what i was thinking just hoping one of you gurus could reverse my F-up
The file is a s300 file - just change the extension from .bin to .skl
