Regarding auto to manual conversion RP17, RP18 & testing
ITR 1102
Post by ITR 1102 »
I read that RP17 should be removed and a jumper added on RP18.
In trying to figure out what is wrong with my ecu, I noticed that at RP18 I have a resister rather than a jumper.
It appears to have a solid blue stripe in the middle of the resister indicating that it is a 60 ohm resistor (and measures 60 ohms with my tester).
Could that have any affect on the ecu's operation?
Also, I read that cutting J1 will return the ecu to stock configuration. If I do cut J1 for testing in another vehicle, will that affect the changes I made at RP17 / 18 ?
If you do not have a zero value (jumper) across RP18 it has not been converted to manual. I would suggest doing that before cutting J1.
ITR 1102
Post by ITR 1102 »
Spunkster wrote:If you do not have a zero value (jumper) across RP18 it has not been converted to manual. I would suggest doing that before cutting J1.
Spunkster,
do you think it would be possible to cause the motor shutting off / acting up?
I don't know if you recall, but a little over a year ago, I posted my .bin from Adrenaline Motorsports. The S200 dealer package was not able to connect to the ecu. I wouldn't suspect it, but could the auto / manual conversion affect the chipped area's communication? Or do you suspect other problems with that issue?
This sounds like there is more going on than just an auto to manual conversion.
ITR 1102
Post by ITR 1102 »
Spunkster wrote:This sounds like there is more going on than just an auto to manual conversion.
the ecu functioned fine for years. then all hell broke loose when I tried to tune with the S200 again. I just wanted to check and be sure that the auto to manual conversion would not be affected when cutting J1
