Need help with the K-Pro
WilsonC
Post by WilsonC »
Hi.. i haven't purchased this product yet but i'm planning on getting a k-pro.
i'm just really confused about how this works... I send in my ECU then they reflash it?? and add some stuff??
can someone explain to me how this k-pro thing works..
i know i should read the site.. i've read it many times.. some how i'm still not getting it.
Is your question about the reflash, or the K-Pro....they are 2 separate things?
WilsonC
Post by WilsonC »
i guess both the Kpro and the reflash..
FrequentFlyer
Post by FrequentFlyer »
If you want the reflash, you have to send your factory ECU, immobilizer and key to Hondata and they will reprogram it with a modified map. This is a one time deal and basically a 3 day process. Overnight your ECU to them, they get it and usually reflash and send it out overnight the same day. So, you're without an RSX for about 3 days.
The Kpro is a user programmable ECU. If you have an '02-04, you will have to send in your ECU much like the reflash, but there is more labor involved as they physically modify the ECU to communicate with a PC via USB. If you have an '05-06, you will need to buy an '02-04 ECU (preferably used to save $$) because the '05-06 ECU cannot be modified into a Kpro. You will also need an '02-04 O2 sensor for this to work.
So again, the reflash is a one shot deal and the Kpro pretty much gives you endless tuning possibilities.
2005 VBP RSX Type S
WilsonC
Post by WilsonC »
I see so.. overall if i don't mind spending money for endless tuning i should go with the K-Pro.
The reprogramming part... I get the program and is it stupid proof?? Are there guides? or do i have to get some hondata expert to come and tune it?
Download the software and check it out then you see exactly how it works. It is in the download section of the website.
