switching between maps???
laziebun
Post by laziebun »
how do i go about switching between maps? i want to do the high and low im a noobie at this unit.....some please help
boostedcivicsir
Re: switching between maps???
Post by boostedcivicsir »
maps or boost?
i dont know of a way to switch between a race gas tune and a pump gas tune,
but as far as boost control,
smanager>open a map>parameters>boost control>enable low high> pick an output to control it>put a switch on that output
laziebun
Post by laziebun »
so lets say im driving down the street with 9psi at low and when i want to hit high boost 15 psi i would just it the ac button to activate it, so thereofr i would be driving with 15 psi with the ac button on?????
boostedcivicsir
not necessarilly unless you have the ac button set to toggle high low. but yes thats basically it. BUT you arent changing the map, you are simply making a map that is good to 15 psi but running low boost in it. and switching from there.
devilz
could be used for car theft protection?
Post by devilz »
would it be fine to create a second fuel table with zero values and have a hidden switch that sets the ecu to that table to stop those nasty car theft's from happening?
or maybe the idle fuel set well so the thief can start the car and feel great about breaking the law..., but as soon as he puts his foot down the car will bog and stop? :)
possible?
H22A Turbo Prelude
sure you can do that
planetspeed
Post by planetspeed »
anything is possible;it just depends on your creativity..But the simplest way to deter theft will be just to put a switch either to the fuel pump or ecu power supply..
