5 BAR MAP WITH s200
sapichyodom
5 BAR MAP WITH s200
Post by sapichyodom »
can i use 5 bar map with S200? where can i get 5 Bar and what kind?
thanks
Yes it can, but I would highly recommend using the s300 instead. We recommend the Motec 5 bar.
sapichyodom
what difference between S200 and S300 on 5 BAr? where can i get 5 Bar and how much? thanks
The s300 is more flexiable as you can set the scalar and offset, whereas the s200 will only work with the Motec 5 bar. You can buy 5 bar MAPs from AEM or Motec.
sapichyodom
how about this http://cgi.ebay.com/ebaymotors/AEM-MAP- ... enameZWDVW
does it work with S200? or i have to get only motec 5 bar map. thanks for your help
The s200 will only work with the motec sensor.
sapichyodom
do you know where can i get it? how much does it cost? thanks
sapichyodom
do you know how to connect motec 5 bar to S200? thanks for your help
It is the same as a 3bar.
sapichyodom
B18C_EJ8
Post by B18C_EJ8 »
Spunkster wrote:The s200 will only work with the motec sensor.
Sorry to hijack, but why is this?
