how to connect innovate LM1 to S200?
sapichyodom
Post by sapichyodom »
how to connect innovate LM1 to S200? thanks
sapichyodom
Re: how to connect innovate LM1 to S200?
anyone!! please help. thanks
IT will be very similar to using a PLX, however some people have had issues with the Innovative widebands, which is why we recommend the PLX. http://www.hondata.com/techplxwiring.html
sapichyodom
-Red wire Power cables for the PLX wideband - connect to switched power in the fuse box
-Black Ground - Attach to solid chassis ground
-White 0-5V Output from wideband - connect to ELD input making sure that the ELD is no longer connected to it (ELD is pin D10 on an OBD1 ECU)
-Gray 0-1V Output for narrowband - connect to white wire from stock O2 plug per instructions below.
But LM-1 have 5 wire. red, black, white, gray and yellow. do you know what is yellow wire for? thanks for your help
