Possible Timing Issue??...........HONDATA Please take a look
My2004RSX
Post by My2004RSX »
- serial number of your K-Pro: 998
- vehicle you have: 2004 Acura RSX Type-S
- ECU you are using: K-Pro K-Series Programmable ECU
Mods: Comptech Supercharger, 3.15 SC Pulley, IPS KSC Cams,
Upgraded Valve Springs, RC-650cc Injectors, Comptech Full Race Header with no CAT, INJEN CAI.........I believe that's everything that's relevant
- specific description of problem: on the KAL I'm using, it's setup to flash the MIL light when it detects knock, the only time I get "significant" knock indications is when I'm at normal driving conditions (50-70mph), from 2k rpm to 3k rpm, above 3K the MIL light stops flashing.
When I did the 3rd gear pull, by itself, I only noticed a couple of spots of what appeared to be knock, but when I did the DL with the shift into 4th through 6th gear, it kept recording while I shifted to 6th and that's where I noticed all the knock in 6th gear from 50mph to 70 mph.
The only thing I've really messed with on the KAL is under "Parameters" "Fuel Trim" tab, I changed the "Overall Fuel Trim" to 2%, not sure if I really did anything there, and under the "Idle" tab, bumped the Duty Cycle adjustment a couple of notches to the right to keep it from stalling.
I've included 2 DL's (3rd Gear Pull) and (3rd Gear Pull with shift to 4th)
Would love to know what you guys see.
Thanks,
Will
There is knock under boost. Reduce the ignition timing under boost.
Your fuel tables need tuning - the long term trim should not get to -11%.
My2004RSX
Post by My2004RSX »
Hondata wrote:There is knock under boost. Reduce the ignition timing under boost.
Thank You very much for the reply!!!!!!!!!!..........
2 quick questions....
1. is the car Ok to drive under NORMAL driving (I.E. not getting stupid with it) ??
2. any recommendations on a good shop in the South Florida area that I can take the car too, to get it tuned correctly???? The required changes needed are way out of my experience.
Thanks Again!!!!!!!!!!!!!!
Will
My2004RSX
Post by My2004RSX »
What would cause the long term fuel to get to -11% ????
I'd recommend not going into boost before the car is tuned.
A long term fuel trim of -11% indicates that the fuel tables are generally too rich out of boost.
My2004RSX
Post by My2004RSX »
Hondata wrote:I'd recommend not going into boost before the car is tuned.
Thank You very much for the reply!!!!!!!!! and awesome site all the way around I do a ton of research on here.......practically live on this site whether logged in or not!!!!!!!!!!!!!!
Thanks Again,
Will
El Verdugo
Post by El Verdugo »
I was looking at his map just to get some general knowledge on the system.
I am seeing that his cam angles are locked in at 50 for the time he is in boost, is this safe and would that also play into the fact that he is having some knock reading? Or is that just because of the fact that he is a little too aggressive on the high cam timing?
I also did notice that he is running a bit rich on top as well especially for a SC.
