Please help, Boost controller doesn't work right!
bigbadboy
Post by bigbadboy »
seems that my BC is not working as it should. runs 7lbs off the WG and when ever i set the %duty cycle it goes whack. 1% duty cycle gives me 15lbs. if i try to do boost by gear anything over "0" or "1" psi of boost will automaticly try to shoot past my boost cut set at 17. anyone got any ideas? i have an Apexi selenoid valve on the S300, i have it set to Selenoid Normally closed ( which is the way i have it set up). thanks for the help
Have you gone through all the different duty cycles with the fixed duty cycle and then created the presure vs. duty cycle chart? Who added the boost control components to the ecu?
bigbadboy
Post by bigbadboy »
so i have to go through all th duty cycles that it shows on that chart even if it hits my boost cut?? also how to do i create a pressure VS duty cycle chart? i got the ecu from xenocron tuning w/ the boost components installed. its a PR4 ECU
turbotypeR
Post by turbotypeR »
first you should try just running off of the wategate. just hook up your pressure line to the wastegate, bypassing the solenoid to make sure you don't have a creeping issue. Then, run it fixed duty cycle at 0 % and it should be the same boost. if that works, raise the duty cycle a bit and on pressure vs duty cycle record how much boost is at what duty cycle. keep doing that raising the duty cycle each time and recording the boost. once you have it up to your highest boost level you want to run, then you can use the boost by gear setting.
92 civic Si
best et:9.43best mph:164
bigbadboy
Post by bigbadboy »
yea i'm not sure if you understand my problem. even at 0% duty cycle i'm runing like 14psi. my WG is fine. i tried a GM selenoid and at 100% duty cycle which shoulld be off the WG it was still 15. 15psi is like the lowest boost i can run no matter what i do. even in the boost by gear setting. if you set the boost by gear at 0 for a value in all gears then it should run off the WG right?? well mine doesn't at 0 it runs 16psi
Have you tried any duty cycles greater than 0, such as 1% or 5%?
You may want to also try duty cycles such as 90% just to see what effects they have.
bigbadboy
Post by bigbadboy »
yea the more cycle the more it tried to boost. its actually really strange because. when the car turns off its like it resets everything to WG spring. i actually have to turn the duty cycle to atleast 50% for the BC to start working. i'm not tuned for anything over 17 right now and my wideband is broke so i don't want to do anything yet. only at 0 or 1% is where the boost won't hit the boost cut. if i set it to solenoid normally open but still leave the solenoid set up as normally closed, when its cold i have to set it to 100% so it won't hit my boost cut or 90% when its like 90-100 outside.
jtcdudeman
Post by jtcdudeman »
sounds similar to a problem I encountered... Run a new lower hose from to bottom side of the wastegate.. Mine busted... I was creeping pretty good even at 1% duty cycle. its a cheap thing to try.
bigbadboy
Post by bigbadboy »
i will try that but i'm just not getting any creep issues at all. i'm ready to just give up and get a different boost controller. i thought it was too good to be true.
If the boost increases as you increase the duty cycle, then it is working correctly. It sounds like you have a leak somewhere and that is causing the boost to be higher than expected.
bigbadboy
Post by bigbadboy »
i'm gonna try and go throught everything before i quit on it. i might try and swtich the solenoid to work as normally open and see if it changes anything. i also got a new WG to try and see if anything changes.
What version of software are you usign from Help, About?
bigbadboy
Post by bigbadboy »
version 1.2.9.0
