Bad ECT fuel compensation
Garrett_si
Post by Garrett_si »
I street tune a B18c5 today using the new ITR stock map in sManager
When the car is colder about 160 F, it run lean (14:1) WOT
when the car is warmer 180-200F, it run 13:1 WOT
the ECT compensation seem not to be good
Is it possible to modify the ECT fuel compensation? I try without succes
You shouldn't be going wot until the car is fully warmed up.
Garrett_si
Spunkster wrote:You shouldn't be going wot until the car is fully warmed up.
the car was warm up, but the thermostat was fluctuating
This is why I saw the bad ECT compensation
I actually replace the thermostat, but the ECT compensation problem still there, if the engine temperature change
You have a problem if the coolant temp is fluctuating between 160 and 200. You may have a bubble or have a bad radiator cap.
Garrett_si
I said the thermostat was defect :wink:
