s300 which ecu should i use
cbryde1212
Post by cbryde1212 »
ok i have a few questions....i am about to purchase the s300
I am currently running a stock p72 on IHE b18c1 with skunk 2 manifold
i know the p72 runs with the iab's which obviously i dont have anymore.
does the s300 have a disable feature for the iabs or should i get a p28 and use that for the s300?
i will be installing a turbo kit also that is why i am purchasing the s300...i am just trying to piece everything together so i will be ready for tuning
thanks in advance
Just use your existing P72 with teh s300. If you no longer have IABs then there is nothign you have to do as the Hoondata system does not get an IAB error.
